Q seat memory
1990_q
Car: 1991 Infiniti Q45
2005 Toyota Camry
Since i had my 90 Q, i tried and tried to get the seat memory to work, but it just doesn't. is there a way i can get it to work or change something to make it work...
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
We'll see how your memory is after double your guaranteed lifetime.
Sorry, couldn't resist :P
thejapino
Car: '93 J30t
I had to do this to my Q before I sold it. I think it goes like this
1. open your door and put the key in the ignition and turn it to the 'ON' position (but don't start the car)
2. leave the key there and get out, close the door
3. wait 15 sec (?not sure how long) open the door
4. it should work again. if not, repeat 1-3 but wait longer. if it still doesn't work then i have the procedure all wrong and you should search google/nico gluck
goody90q45
Car: 1992 Infiniti Q45 (sold)
Instructions are correct but wait a minimum of 1 minute with the door closed.
Also try blowing out the ignition cylinder with compressed air.
1990_q
2005 Toyota Camry
well the seat does move, but we i set the memory with the buttons on the door, the seats dont move when i press it...
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Is your "cancel" button pressed? It's the button beneath the power steering wheel adjustment. If it's pressed, seat memory is disabled.
