ag240 wrote:bump
k lemmie get this straight (kinda slow at moment ) so basically if i do this i can take the harness, ecu, motor from the s13 and put it right on to the s14 chassis?
urg... srry for all the dum@ss posts on this, im just trying to get this as bug-free as possible before i do it in the summer....... im gonna save up til then and boost it
everything is the same exept:
you need to swap: s14 tps, exhaust mani for s14 if you are using s14 down pipe,if you still want the heater, redo the heater hoses to fit , cuz s14 hoses are thicker than s13, need to change distrubitor from a s14, cuz s13 has external coil, s14 does not, you need a s14 maf, if you still want a/c you need to swap over the s14 compressor bracket to the s13 block,, and thats it,
