If it's not clogged, it could just be the injector giving out.jmorasch wrote: been having what seems like fuel Issues with 91Q.got a fuel pump from goody one that was known to be good and then grounded the fpcu,and its still running with a miss like sputter.theres really no specialty shops around here,or Id ride like the haitian really soon. Im wondering if Ive got a clogged injector? would it be of any harm to run some BG through the tank? Im also wondering if the quality of gas here in the midwest is dropping because the misses Q done the exact same thing going to work one morning and stopped soon after it started.I went and got some injector cleaner and ran it through and it quit on the way home. I dont want to mess this motor up driving it to see if BG clears it up though.IM gonna check the injectors see what kinda reading Im getting. does grounding the fpcu definatly let you know if the units good or bad?
tried some iso already,Ive been womdering the same thing???There was a thread on the states required to mark the pumps by the feds awhile back and kansas and Mo. were the only ones not required if I remember right....anywayze,Im off to pick up some lectra-clean crc and hit the maf,check things out from there. WILL IT HURT THE VH TO RUN IT LIKE THIS WITH SOME BG INJECTOR CLEANER TRYIN SEE IF MAYBE WE ARE DEALING WITH A DIRT ISSUE ??????after I get the maf cleaned out.maxnix wrote:Try some ISO-Heet also as I bet you are in an ethanol area.
BG 44K isn't an "Autozone Quick Fix".jmorasch wrote: NO,I havent replaced the FPCU. when in nuetral with the car running at idle,you wouldnt really know theres a miss or sputter unless you listen close at the rear of the car.It does have dual exhaust system on it from the previous owner. you can puy your hand on the top of the engine and feel a slight jitter to ie.otherwise you wouldnt really know until you put it itno drive.the its almost like it got a bad motor mount,but the shutters not as radical.It shudders on take off,its a strange shudder,miss kinda deal???its really frusterating.....at about 2k on the Rs,it seems to smooth out until it shifts.then it goes through the same cycle again.(Ive got 1st gear start TCU) ID like to put some BG injector cleaner into it and drive it back and forth to work,but Im not big on the autozone type quick fixes so to speak.I want to know what the problem is and resolve it !!! I grounded the FPCU after I put this other pump in...and it still ran the same.after I grounded it out,I pulled it out of the garage and parked it.gave myself a break. disconnected the wire from the fpcu and plugged it back in.next day I pulled it back in and did the O2 sensor,and though I couldnt believe the color of the cleaner after it came off the O2 it was brownish black,there was no diffrence in things when I fired it back up???
It sounds like you may have a plugged injeector or two. What's the history of your injectors/fuel rail/engine. Had it/they been sitting in a salvage yard for a while?jmorasch wrote: the sputters not a spitting,nor sputter through the exhaust as far as I can tell,though like I said you can hear the slight miss ......theres really no changes other then when the Rs reach a certain point it seems to fade somewhat until it shifts again.
Your Q had a broken chain? Timing chain? Did it run better before and this problem just come about? Or has it been a slight nuisance that's become worse?jmorasch wrote: I agree....Im doing alot of guessing here,without any facts,FP and checking the injectors is something I need to do next!!!! this car sat for about 3 yrs before I bought it.this is the Q that was suppose to have a broken chain. anyhow im gonna check the FP and ohme the injectors this weekend and go from there. If an injector doesnt ohme properly does that mean its plugged or bad??? wes described the charactoristics of how the engines running,IM going to start on things this weekend.....thanks for the help,feedback and parts.hoods struts worked out great!!!!
