Sopdadope »
https://forums.nicoclub.com/sopdadope-u303.html
Fri Nov 15, 2002 7:15 pm
Optima batteries light and compact? Depends on which battery in question. After playing around with Optima's, I wouldn't describe "lightness" as being one of their qualities. The Optima Yellow Top, the battery I'd recommend you use in your case, weighs 48lbs. Because of the side terminals, they can and probably will rub against the fuse box in an early Q.
The battery tie-down will be an obstruction as well. Also keep in mind these batteries retail over $170 at most stereo merchants. They could be found cheaper online but expensive shipping nullifies any savings there. I did the stereo install on my Q and trying to find room for 0 gauge power wire is HARD. This is not something I would recommend you do. I ran inside the car because exposure to moisture, dirt, debris and salt chaps the insulation. If you could run it inside a conduit you should be ok, but I still prefer running power wire through the interior.
If lightness + compactness is a priority, try Hawker Genesis batteries. I've seen them used time and again in auto-x cars. Dimensions are 8x4x6' and weigh 15lbs.
