Q lumpy idle
yidal8
My 91Q developed this lumpy , or uneven idle . I can feel the car shaking slightly , both in Drive , or Neutral . Everything else appears normal .Any suggestions ?
Rex
Car: None
Sounds very "injector"-ish. Try searching in Inf Online Mech fro injector, I think you'll find some help.
nuQ
Car: 2003 Infiniti M45
2009 Dodge Caliber SXT
CHECK THE MAF CONNECTIONS!!! jiggle it slightly and see if the idle moves. mine did the same thing, cleaned up the connections, put bulb grease on the brass, problem solved!jeff
Q451990
Squeaze the fuel line (the one with the filter) closed with a pair of plyers for a second or so and then let go - with the car at idle. Only a second though! This will build up some additional pressure and may blast some of the crud off of the injector screens.
Also run a seach for "ohm test" for the injectors. The bouncing engine definately sounds like a dead injector to me.
Heath
Assuming its an injector problem, here's some fun threads:
http://www.nicoclub.com/forums...ctors
Oh yeah, consider an injector rail flush and a couple cans of BG44k, available at everythinginfiniti.com.
-Jesda
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Heath: Thats an interesting trick, I may have to try that!
Q451990
Yet another cool thing Q45Tech mentioned when I was in Atlanta. Just limit pinching the line for a second or maybe two, but NO LONGER! You don't want something to break loose elsewhere from the pressure build-up!
Heath
