Q idling higher then normal
spankme234
Car: 1991 q45
The last couple times i started up the Q it would rev th engine up to 2 k like normal but then it will only come down to about 1,400, instead of 600. The weird thing is when i throw it into drive it will go back down. Also my cars alignment is completely screwed. If i let go of the wheel it looks like im trying to get 5 lines over to the left . Is getting the alignment fixed on the q the same as any other car?
rsiwicki
Car: 95 Q45T
I have only had problems anywhere I go except for the one dealer here in Miami. They seem to know how to get my beast pointed straight. I had it to the Goodyear dealer 3 times within 2 months for a pull to the right and they could not get it pointed straight. Took it the the dealer....no problem. I now have a copy of the alignment specs that the dealer gave it so it should be all good if I take it to somebody else besides the dealer.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Saturday night, I was taking my mom and wife out to dinner. It was my mom's birthday. A nut in a Dodge truck blocked me for a little too long while I was leaving. I wanted to show him how much I appreciated him, by smoking the rear tires a bit. That was stupid.
I felt a "pop" under my foot whil I had it to the floor. After that, the idle wouldn't drop below 1400 RPM.
I wonder if your problem is the same problem I am having.
My idle problem is intermittent. Depending on whather its a warm start or what the climate is, it may idle around 1200 unless its in drive. Dont have a clue what it is, but the plenum is coming off this summer anyway.
MR. Q
It could be the fast idle cam that warms the engine up.
Mr.Q45a
Car: 1994 Q45, 1995 Q45a
Jeff
You may want to check the timing, it is possible that the Camshaft positioning sensor moved to which limits when you jumped on it . And that was the snap you heard and felt.
EFEC page 35 - 36 of the 1995 factory service manual Delineates the timing procedure .
I suggest this because the factory service manual indicates that idling problems can be traced back to the oxygen sensor or improper timing.
I think it's worth a try
Best regards
spankme234
Car: 1991 q45
Its only a problem when i have it in park.Sometimes its a lower rpm when in park like around 800 or somtimes its higher like 1500. Car drives fine and as soon as i put it into drive it will idle at 600 again.
