Thanks a lot!.............2.2----3.2 [brand new] *>3.2>4.2 noisey at idle.
After we get 20 measurements we can find the mean brand new and the mean noisey............extrapolate the failure current.
Again my guess is 5.0 amps at idle.
Your 7.2 during first 10 seconds after crank is the killer [also WOT] with a 15 amp fuse one could assume this is normal.
Roughly what a non speed controlled pump draws all the time.
http://www.delphi.com/pdf/e/fuel_pump_medhigh.pdf
From the above 8.0 amps max 6.5 amp typical at 13.5 volts see the chart on page 2.
"""The instrument is a personal computer-based system with menu-driven software and is housed in a rugged case that fits within the size restrictions of carry-on luggage. The unit is battery powered and can be used either in the hangar or on the flight line by maintenance personnel.
ORNL's current signature analysis works either remotely or locally by connecting probes to electrical lines carrying current to the fuel pump.
"Our system measures changes in the electric current drawn by a motor as an indicator of changes in the mechanical load that it is driving," said Howard Haynes, one of the pioneers of the technology. "In this case, the changes in current reflect wear in either the pump or motor assembly."
By using the instrument, mechanics can identify wear in the fuel pump that has exceeded allowable tolerances -– remotely and under harsh environments such as those with the C-141, where the pumps are submerged in the fuel. """"""""""
