MECPInstaller »
https://forums.nicoclub.com/mecpinstaller-u9687.html
Sat Sep 04, 2004 8:40 pm
I never really sanded between build up layers until i started getting close when i was filling with bondo, I'd just use 60 or 80 grit if theres some lumps or where some of the glass matte lifts (wanna try to keep it all down on the project but when the resin begins to cure yoru paintbrush likes to lift some up with it). Make sure to wait till the resin is hard to start sanding or else you'll be wasting sooo much sandpaper. I always use 80 grit on the glass or bondo until its really taken the shape i want, after all the big dips and humps are removed. after that, it depends on what your wanting to cover your project with, if your doing vinyl a 180 or 220 grit sanded surface is all you need. If your going to paint though be ready for lots and lots of sanding.
Id do step ups of 180, 220, maybe 300's if you want to or find it, then to the wet sanding. Starting with 400 then 600 and finishing in either 1000 or 1500. You'll have a muddy freakin mess when your done. In my boxes i half assed the sanding cause i needed to get semi done before i went up to toronto so i only spent maybe 3 hours or so wet sanding them, could have easily spent another 3-5 hours. Depending on whether i'm going to paint, do vinyl or maybe rip off ayjays idea and do carbon fiber keep a bucket full of water next to you and constatly keep cleaning and rewetting the paper and you won't have to buy to much of it.
With screen enclosure i'd just use 1/4 inch mdf or really any wood(whatever you've got laying around), with the mdf make sure to drill pilot holes for yoru screws or it'll shred and crack. if you wanted after its built you could round the edges off with a router or some sandpaper. for painting you could do direct paint on the mdf but would soak up alot of it, personally i'd paint a thin layer of resinon the parts of it that'll be seen and just sand that smooth then you'll have a really good paintable surface.
