sultan »
https://forums.nicoclub.com/sultan-u295.html
Thu Jan 16, 2003 8:26 am
I noticed the thread about wanting a Q faq, and i have been working on this for the last week. but, before someone else starts to make their own i decided to start posting mine. this is only engine and transmission specs. car dimensions, year by year changes, performance times, maintenance, mods, etc. will follow shortly when i have the time. if anything is incorrect please post the correct info. also post your opinions. i think any changes that need to be made should be made before it is made a sticky by a mod, therefore not having responses in the faq. i would also like to thank dennis in advance for all the info he's posted. i will use a lot of his posts in the faq. all data is from these boards, various internet sites, magazines and the 94 service manual, as that's the year i have. i would have included redline but i can't find numbers that agree for the 02 Q, anywhere from 6600 to 6900.
Q45 FAQ
Engine:
90-96 4.5L DOHC 32v V8 (VH45DE)4494 cc274 ci93x82.7 mm10.2:1 compressionHP: 278 at 6000 rpmTorque: 292 lb-ft at 4000 rpm
97-01 4.1L DOHC 32v V8 (VH41DE)4130 cc252 ci93x76 mm10.5:1 compressionHP: 266 at 5600 rpmTorque: 278 lb-ft at 4000 rpm
02-? 4.5L DOHC 32v V8 (VK45DE)4494 cc274 ci93x82.7 mm10.5:1 compressionHP: 340 at 6400 rpmTorque: 333 lb-ft at 4000 rpm
Transmission:
90-93RE4R03A 51x65 transmission 4 speed autoGear Ratio1st 2.784:12nd 1.544:13rd 1.000:14th 0.694:1R200V viscous limited slip differentialFinal Drive Ratio: 3.538:1
94-96 RE4R03A 51x79 transmission4 speed autoGear Ratio1st 2.569:12nd 1.479:13rd 1.000:14th 0.694:1R200V viscous limited slip differentialFinal Drive Ratio: 3.538:1
97-014 speed autoGear Ratio 1st 2.569 :1 2nd 1.479 :1 3rd 1.000 :1 4th 0.694 :1 Reverse 2.275:1Final Drive Ratio: 3.694 :1
02-?5 speed auto1st 3.54:12nd 2.26:13rd 1.47:14th 1.00:15th 0.83:1Final Drive Ratio: 3.13:1
