dnashing »
https://forums.nicoclub.com/dnashing-u120745.html
Sun Dec 07, 2008 6:24 pm
The following dash 'warning lights' started to illuminate about two weeks ago;Low Battery, TCS, Check Engine, etc. Went ahead and eventually replaced the alternator and the battery. Problem still persists. Had 14.2 volts when the new alternator went in, but daytime running lights flickered, next time I started it, the battery only had 13 volts at idle.next time I started the car the battery was 12 volts at idle.
Pulled daytime running lights module and relay now there is no daytime running lights at all.
Would a CONSULT test be the easiest way to diagnose my problem?
Alternator was rebuilt to heavy duty spec's and new battery. Checked for short circuits with no findings.
confusingly complex
thanks
