jser »
https://forums.nicoclub.com/jser-u14684.html
Fri Apr 23, 2004 12:31 pm
hey NISTECH,
so i'm doing my homework here before i jump in.all i need to is remove the oil pump and replace the spindle do i need to remove the front assmbly inorder to this. read and got confuse i have a chilton. just by looking at it seems you could? i also need to remove the oil pan, remember i**idoit** dropped a rubber part in there!
and also i found a tread that the same problem...and yes you helped out there too....THANKS!!!!!!
