Haitian_King wrote:Now when you did this, what time of day was it? I tried waxing the car after a wash one day while it was sunny and the results were not desirable.
6 hours doesn't afford much time out of the sun. Did you do it indoors? Did you wash the car first? I've been using a waterless wash that you spray on, let it haze, then buff off. It's been a while since I've used water on my Q.
What's the best wheel cleaner? I bought some Nascar foaming spray that doesn't work very well. Plus, the BBS wheels aren't the easiest to clean.
Always hand wash right before polishing/waxing and only polish/wax in the shade or in the garage if it is windy to prevent airbourne dust/dirt from landing on the finish which will then be ground into the paint by the polishing machine.If polishing in the garage,good strong flourescent or halogen lighting helps you see surface scratches/watermarks/blemishes easier and allows you to check your results as you work
Modified by qship96 at 12:24 PM 9/20/2007
