Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Apr 05, 2007 10:59 am
You can run it like that for a little while. Old turbos weren't water cooled, and you can still buy a turbo that isn't water cooled. What will happen, though, is that the turbo will rely on oil to keep the CHRA cool. And that will greatly kill the lifespan of your oil, making you have to change your oil more often. Also, the long term durability of a turbo that is designed for a water cooled CHRA will greatly decrease if you run it for very long with the coolant blocked off.
My suggestion is to figure out the problem you're having with the coolant line and fix it. What is the problem? Leaky line? Either get a new one/make a new one, or look at getting some braided steel lines. Our cars were meant to have water cooled turbos, and I'm a firm believer that they should stay that way.
