texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Fri Sep 24, 2004 12:47 pm
A number of mfg's have offered versions of variable stiffness shocks over the years. This is TOTALLY DIFFERENT than true 'active suspension' like the Q45a has. ACTIVE SUSPENSION (actually semi active since it still uses conventional springs for 60% of the curb weight support) utilizes stored high pressure oil to force the wheels down into holes, adds pressure to the outside wheels when cornering,etc. Adjustable dampening can emulate a lot of the Q45a feel without the weight and mechanical complexity of hydraulics, and can even improve on some areas like high frequency response (short bumps) The difficulty with adjustable dampeing is the lack of enough energy to drive the wheels down into a hole. Thus the car body will drop considerably more tha a Q45a type system. If the road presents 'bumps' more than 'holes' or droops, then adjustable shocks can/may do a good job. Its a compromise system--lighter weight, lower power consumption, but lower benefits too.
