gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Mon Jun 20, 2005 5:42 pm
looks kinda dangerous IMO. where are the arms for your stand on the top?? your stand should have come w/ 2 more arms for the top so it can span much further than that.
what grade bolts are you using? make sure you are using some automotive grade stuff, and not your local home depot fastener.
mine is set up on a stand right now the exact same way as yours, except my lower arms can reach into the corners because my stand has 4 arms in total. part of the reason you want to put it on the stand is so you can flip the motor upside down to work on the pan,take out mains, whatever. with the way you have it, i definitely wouldnt try to flip it upside down.
maybe look into buying a different stand that has all 4 arms.. they're only like $30..
