thekawaii wrote:do you think that manifold will work on KA24E? Why is KA24DE manifold don't work with single cam KA?hm....... hard to find mani........
I found one for 450 bucks
The DE manifold doesn't fit because it has a different flange bolt pattern, and the exhaust ports are positioned in a different way. It won't match up whatsoever.
That manifold will probably bolt in, but you probably won't be able to use it on a 240sx. Notice that he said he made it for a stanza....
Turbo setups are expensive. Plan to spend at least $1000-1500 if you don't make any parts yourself.
