Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Oct 03, 2003 2:51 pm
Another interesting fact is the week before, I had changed my spark plugs at 56,000 miles - 3.2 years]. The plugs looked rough from some blowby and oil/deposits.We did 4 per day [limited time] and did compression test at the same time...............all readings were below factory spec but were done with the engine cold [maybe 75-100F] so the rings were not sealing well COLD............some were below 100 psi [145 psi minimum].....adding oil brought some as high as 220 psi.
Yet a warm [176F] power balance is/was perfect. Rings seal ok once heat expanded.
When you are dealing with high mileage Q engines different criteria need to be evaluated.Idle smoothness, power balance, oil burning, smoke on WOT/idle/startup, acceleration or dyno test.
My motor mounts were changed at 120k [6/98]...........5.3 years and or 136k seems to be the life limit as we measured displacement under load vs new units.
