Pwr Steering pulley bent! Need pulley
300Plus
Car: 1995 S14 w/ Rb25det Series II
My rb25 pump came broken and bent from Japan, so I got one from a guy on ebay a few weeks back, turns out that pulley has a rolled outter edge and is slightly bent. I'm screwed.
A part number to the pulley alone would be awesome if someone has it!!!Is there any USDM pulleys that swap on ? or does anyone have a dead pump with a straight pulley ? Thanks in advance guys!
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
Funny how I got the same problem. Bought mine off ebay to only find out the pulley alone was bent when you only spun it. Hahaha now I need to replace the pulley aswell.
kjlindgr
I've got an anodized aluminum Greddy one I'd sell. It'd for an RB26 so I'm not sure if the pulley is the same or not. Someone could probably verify though.
300Plus
how much, if it does fit ?
Will a KA pulley work ? I'll take anything info at this point guys.
kjlindgr
$50 shipped. It was on my car for about 100 miles so it's pretty new.
Ramius83
Car: 1995 240sx SE
Just go to a Pull-a-Part place and look at all the Nissan Power steering pumps and pulleys. They all share the similar size 19 bolt/nut. And they usually all share the same offset. Regardless of the zie of the pulley won't matter, just get a shorter or longer belt to compensate.
But of course, having the RB2* pulley would be best. Just giving you alternatives.
300Plus
kjlindgr wrote:$50 shipped. It was on my car for about 100 miles so it's pretty new.
I'll be emailing you very shortly
Ramius83 wrote:Just go to a Pull-a-Part place and look at all the Nissan Power steering pumps and pulleys. They all share the similar size 19 bolt/nut. And they usually all share the same offset. Regardless of the zie of the pulley won't matter, just get a shorter or longer belt to compensate.
I have compared the KA and the Z32's pulley and both are held on by a bolt/nut. The rb25 pulley is pressed in and no bolt is used. Would love to go the cheaper route but can't find a match.
Can anyone confirm the RB26 pulley or pump will work on the RB25?
Modified by 300Plus at 11:35 AM 7/12/2007
