PWR Performance radiatorS FOR J30??
madmax88
Car: my car
PWR Performance products introduces it all-aluminum, "stock fit" radiator for the Fairlady. With a 37mm thick 2-row core that is thicker than the OE Nissan PWR Performance, there is the additional cooling capacity to handle the heat generated by highly tuned 300zx's. With stock height and length, these radiators fit into factory location without any modification for easy installation. Mounting brackets allow for the use of the stock fan, eliminating the need to purchase an aftermarket fan. Polished to a beautiful finish, this radiator enhances the engine compartment of any Z///////// WILL THIS FIT MY J30 ???:ylsuper
Eswift
Car: should be obvious enough
dont know if its an exact fit, doubt it. with money, you can get anything to fit anywhere. the question is, why would you need it?
