DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Jan 20, 2003 8:16 am
Look at what labor will be done just to replace the pump and go from there. First thing is the belts (~$25). If yours are old or cracking replace them. Look at the fan (~$50) too for cracks. They have been known to fall apart if neglected for too long, easily destroying the $400 radiator. This isn't a direct overlap, but consider replacing the thermostat(~$10) and the thermostat housing (~$60), since they're right next door to the water pump. New upper and lower radiator hoses (~$10 each) aren't a bad idea either, though you can leave them on to do the pump. I recommend a piece of cardboard over the radiator to protect the very delicate fins while you're working on the car.
