it always does it though, every time I fill the tank all the way up the gas mileage is worse?it makes no sence at all, I have even tried to fill it up and drive like a pansy to save gas and the mileage still sucks...Gimli G35 wrote:i have no idea now . im still saying it weight it could be ... types of road conditions , what you were using in the car ( A\C and all that ). thats all i can think of that might cause that problem..
I don't have Navi... The method I use is the one you just pointed out...arizonaferrell wrote:Hey Ken,
I've noticed a similar (However different) issue on my G as well.... When I first FILL up the tank to the top and reset my MPG gauge, it reads 28MPG for the first 30-50 miles, then gradually drops down to 20-21 MPG by the end of the tank... I'm getting 360-385 miles per tank of premium...
You should know that the MPG reading with the on board computer is not a truly accurate gauge of your miles per gallon usage. The most accurate way to determine your MPG is to fill up the tank (from empty), then reset your trip meter... run down the tank til it's on fumes, then divide the number of miles you drove by the number of gallons you put in the tank... this will give you an exact MPG reading...
EXAMPLE:
18 gallons of fuel385 miles driven
385 Divided by 18 = 21.39 MPG
