Cyberkreig wrote:The FSM is good.. but doesnt it matter which position you replace the rockers and shims?
YES
if you just threw this thing back together, it's going to be in SAD shape when it runs. i hope you don't break anything. if you have any desire to keep your engine running in decent shape and in one piece, i advize you to shim it yourself if you're capable (sounds like maybe you aren't) or take it to a shop and have them do it for you. i can tell you it will probably be quite expensive for the rather small amount of time/effort it actually takes, but this is something you do NOT want to screw up. with the wrong shims in the wrong places you run the risk of damaging the hydraulic lifters by compressing them too much or extending them too much.
moral of the story: FIX IT SO YOU DON'T KILL YOUR ENGINE
