Structure240sx wrote:overheating of the engine is not due to the header. its the cooling system that is your problem.
thanks, that's good to know.
The only reason I thought it would be the headers was that I never had this problem until I installed the headers, which consequently removed the stock exhaust manifold heatshield. So, I figured since more heat was coming from the headers, that would mean the engine bay would be hotter, especially when I'm idling in traffic.
I figured if I wrap the headers or get a shield, that will push the heat and make it dissipate further down the line away from the engine bay.
Can you recommend a way for me to check my cooling system? The fan works, but I was planning on changing it to the 2 electrical fan system. I was also thinking about upgrading the radiator if it would help out.
Another possibility for me would be to get a vented carbon fiber hood, which should allow more air to flow through the engine bay and keep temperatures down.
Thanks for your response, any help is greatly appreciated.
*EDIT: maybe overheating is the wrong word or I am using it incorrectly. The engine doesn't die out or smoke up. When I'm in traffic for a long period of time during the day, say for 15 minutes plus, the temperature gauge starts climbing up. If I blast the heat, the temperature will start to go back down to normal. I know this is the common solution to this problem, but I would prefer to fix it rather than do that step every time, especially since it's already hot enough during the summer
