putting gtr 444cc injectors in a sr20det
jeffdetty23
Car: 1990 se 240sx with sr20det swap
I was wondering who else has done this..i have the inectors...an ecu programmed for them..a r33 gtr fuel pump..the top feed fuel rail and a blox racing fpr...what i am on here asking today is what injector connector is need for the gtr injectors...can it only be a gtr or maybe 300zx 90-96 connectors trying to find out which ones are compatible ...thanx for your time
DuckyD
Car: 1995 240SX
I am unfamiliar with the GTR injectors, but knowing Nissan and how simple they are... I would take an injector to the local junkyard and see if you can find some clips that work. Maybe a Maxima, maybe a Infiniti Q, probably a 300ZX.
northstar ninja
Car: 74 260Z, 92 240sx hatch.
I dont think GTR injectors are compatable. Sr's use the same high impedance as a RB25det, IIRC. The GTR used low impedance injectors. You would have to wire in a resistor pack... Someone told me that you risk frying the ecu without the resistors...
