Putting a Lip on end of Intercooler Piping?
Tr0uble
Car: S13.5sx
Was wondering how you put the lip/hump on the end of intercooler piping to keep the silicone coupling from blowing off under pressure. I had to cut my "bolt on" hot pipe to get it to fit where it's supposed to. Problem now is it doesn't have the lip to keep the coupling from blowing off under wide open throttle boost.
Is there a special tool for this?or any ideas on what type of company can put that on there?Not many custom places here in the carolinas.
mutiny
Car: 1989 240SX
You could try flaring the piping, but I think the lips are generally welded on the piping or part of the piping somehow? I vote welding all the piping into one piece instead of coupling
Florida240sx
I had a guy put some spot welds around my pipe then I took to a grinder and smoothed them down... No problems at 25psi
pr240sx
Or use hairspray where the silicone conectors meet the pipe.
By the way, I think that is called a bead, IIRC
480sx
Car: 1996 Pearl White 240sx
All you do is get someone who can tig aluminum and get them to use a pretty good ammount of filler rod. Or you could use T-bolts/hairspray.
Tr0uble
Car: S13.5sx
mutiny wrote:You could try flaring the piping, but I think the lips are generally welded on the piping or part of the piping somehow? I vote welding all the piping into one piece instead of coupling
It'd probably be more aesthetic to start from scratch rather than have 2 weld lines on the piping. I had to take a section out of the "bolt on" piping to get the angle I needed. I'll more than likely have a couple custom pipes made here in town later. I just want a temp fix until I get some more time to talk to some people.
It's pretty annoying driving around town and have it randomly blowing loose.
Hairspray sounds like a pretty cool idea.
AxiOn419
Car: 1991 240sx SE Super-Hicas w/ RB20DET
I have never dealt with this situation but I like solving problems so here are my ridiculous suggestions:
1- What if you used duct tape or electrical tape around the end of the intercooler piping in order to make a tighter fit as well as a better grip. I imagine rubber(the tapes non sticky surface) and silicone stick better together than metal and silicone.
2- What about a JB Weld lip?
mutiny
Car: 1989 240SX
or grab a pipe or something and flare it out like a suggested earlier
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Either flare it or get some type of rubber glue from the parts store.
Only options you have besides starting over or getting someone to tig a bead on the end which is what I would do.
masterbunta
The second reason for slippage is the oiliness that forms on the two surfaces. You can temporarily fix the problem by degreasing the two surfaces with a non-residue carb cleaner. When the pipe and the hose are free from all grease, they will hold much better.
You really need to get some type of lip on the pipe at some point.
Taba13
Car: WTB another 240sx
IF you are handy and or on a budget, you can flare the pipe easily yourself with a pair of good sized vice-grips and time.
since most all IC piping is aluminium it is fairly easy to bend out of shape and or flare.
take the vice grips and go to town by sliding them over the pipe wall about a half inch and bending outward, where the time come sin is because you have to try and get it even and a good non kinked bend all the way around the diameter of the pipe.
worked for me at 16+ psi
pr240sx
Or creat a rough surface on the pipingThe tape, JB weld , etc could be eaten my the turbo,engine and cause a disaster.
Roughen up the pipe and use hairspray. If you need more grip, drill the pipe and use screws sealed with a small dab of silicone. Seems brutal but works perfectly!!
Tr0uble
Car: S13.5sx
Thanks for the suggestion guys.
drmerdp
Totally recommend having someone tig a bead around the pipe.
Its the end all solution, plus think about it what if you have to remove the coupling eventually, more bull****.
Whoa, whoa, whoa.
Too much ghetto-rigging.
Eastwood sells an affordable bead roller. Buy one and rent it out to folks - It'd pay for itself pretty quickly.
Tr0uble
Car: S13.5sx
AZhitman wrote:Whoa, whoa, whoa.
Thanks Az, just the info I was looking for
So a bead roller is what it's called
AceInhole
Harbor Freight also sells a bead roller, with changeable tips for flaring/ shearing.
http://www.harborfreight.com/c...34104
pr240sx
But we are NICO!!We like to improvise!!
Those are handy tools, but I prefer to ïnvest in speed parts instead.Although a TIG welder and a bead roller will pay almost instantly when you start your own jobs!!
480sx
Lol you'll need to do a few jobs to pay off the price of a good tig welder. The trick is buying the ones that can go cold enough to do really thin alum. Then it gets expencive..
