zerothread?id=183606
The automatic ECU will work, you just won't have a rev limiter or a speed limiter. You will need to source a clutch pedal assembly, clutch master cylinder, clutch hardline, and possibly a slave cylinder if your transmission doesn't have one on it. That write-up should cover most of the basics.
