WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sat Dec 21, 2002 12:15 pm
Sure you can Jeremy, But it really isn't as straight forward as that. You'll need all the parts that go along with a turbo, even if running low boost. Things such as the exhaust manifold, fuel pressure regulator, down pipe, some sort of boost control depending on what you get the turbine off of.
In the end I don't think it would be worth it. If I were you, I would get a N2O kit from NOS and use that for some fun until your rebuild is done. Plus you can keep the N2O on the new engine.
WD
