ken240sx »
https://forums.nicoclub.com/ken240sx-u27409.html
Wed May 21, 2008 6:35 am
do you have the jwt ecu yet? if you don't don't buy one, they are horribly overpriced. Look up emance, he'll do your ecufor 125-150ish and it's really just as good or better. Also, you'll want a recirc, because the MAFS meters the air coming in and when the bov spits out a burst of air, the car runs way rich because it planned for a certain amount of air and the bov just shout out half of it. On top of that you get the benefits of air rushing back into the system before the turbine which will help your turbo stay spooled up more than if you had an atmospheric bov between shifts. If you don't go recirc you're going to want to do a blow-thru set-up, where you locate your MAFS between the intercooler and the throttle body.
