Put this in a sticky!
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
http://www.frsport.com/sr20det....html possibly the FAQ sticky?
240sxs1377
Car: 1993 240SX
omg sticky that. thats some sweet info.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
That's a good link, however it is incomplete.
I used that guide, and they fail to tell you that there's two green/yellow wires, only one of which needs to be connected. You need to multimeter the pinouts to find out which one is the a/c relay.
Also, in the part where they tell you to connect the blue/red and black/red to the black/red, they fail to tell you that there are two blue/reds that need to be connected (one is coilpack power, one is power for something else, i forget). Also, when they say to connect the brown wire to any +12v switched, they don't mention any nearby +12v switched wires. I hooked mine up to the black/white (ECU power). I'm not sure if this will be +12v switched or +12v constant, because there is a red/black wire that is ECU relay which may be +12v switched while the black/white is constant +12v to the ECU relay.
Can anybody clear this up?
Hijacker
Car: '92 240sx Convertible
'94 F-150
I'll add it to the FAQ with the stipulation of Amoeb's issues.
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
Nice thread. I wonder if there's a similar one for an s14 notchtop, into a usdm s14.
koukicody
Car: 93 Mazda Miata
*cough cough* zerothread?id=185614
