Postby
ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.htmlSat Jun 12, 2004 3:10 pm
My cat-back is making a weird "put put put" noise when I'm off the gas and around 2000 RPM... I'm running a 2.25 pipe from the cat with no resonator. How can I get rid of this annoying/embarassing put put put
Postby
BadMojo »
https://forums.nicoclub.com/badmojo-u5205.htmlSat Jun 12, 2004 3:10 pm
Possibly an exhaust leak? Generally an exhaust leak will be more of a ticking sound, but it's worth a shot. Did you just install this exhaust? Did you do it yourself?
Postby
Fighto78 »
https://forums.nicoclub.com/fighto78-u7812.htmlSat Jun 12, 2004 3:10 pm
Are you sure it's not back firing? Are you on the throttle or coming off of it? Exhaust often makes back firing a lot louder than it is with the stock muffler.
Postby
HaveBlue »
https://forums.nicoclub.com/haveblue-u1587.htmlSat Jun 12, 2004 3:10 pm
not enough back-pressure at partial throttle I would guess. Mine makes the same noises, kinda a blub-blub-blub noise like a old hot rod or something, just much quieter.
Postby
ILikeMy240sx »
Fighto78 wrote:Are you sure it's not back firing? Are you on the throttle or coming off of it? Exhaust often makes back firing a lot louder than it is with the stock muffler.
It onyl happens when Im off the throttle.. and when the RPM drops to around 2000 rpm... It's the loudest in 1st gear.
Postby
ZULU »
https://forums.nicoclub.com/zulu-u10890.htmlSat Jun 12, 2004 3:10 pm
mine pops all the time , APEXI N1 catback... its normal from what i hear. It happens when i let off the gas as well... I get it in 4th most often, probably because I drive in 4th most
