bigE »
https://forums.nicoclub.com/bige-u7035.html
Fri May 09, 2003 8:25 am
I ran the Koni yellows with my Pro- kit, and they're awesome. So I would reccomend Koni's for the performance, installation wise, no. The fronts were a pain in the *** to install, had to cut up the oem strut tube, cause the front Koni strut was just an insert. Once they were installed they were fine, the rears are easy, like every other shock, adjustability wise, the fronts are easy, just turn the knob on the top, the rears, yo actually have to remove the strut, and take off the spring to adjust it.
The performance is nice, but they're a ***** to install and adjust. Just figured I'd give you a little insight to some of the strut options.
Eric
