WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri Oct 09, 2009 5:04 am
I wouldn't suggest cutting your teeth on a turbo kit. If you've done other mods before, cam swap, headers and a cat-back, things like that then you should have no problems.
I suggest focusing on one section at a time if you do decide to DIY. Don't take everything apart at once. Take something off, then swap in the replacement part.
If you're going with low boost, say 8 psi or lower then you can use a simple FMU for fuel. The best cars are always pre-planned and as simple as possible. After a year or two and reading/talking to us you'll be ready to step up to higher boost and better tuning options.
Don't buy any eBay kits, they are junk. For every success story there are 300 failures...and that's not an exaggeration.
WD
