NismoChi wrote:I used the two pin(33 & 35) on the TCU harness to test the resistance og the fluid temp sensor, and the resitance came to 0.6 k ohm (it was taken in the morning, have not driven the car for a least 10hrs) , according to the FSM the valve should be 2.5k ohm - 0.3k ohm, from cold to hot, with the 0.6k ohm from the test, i'm pretty sure that i need a new temp sensor, but for now, i am going to put in a inline resistor like the Q45 guy, and hope it would fix it. Now the question is, i went to radioshacks trying to get a 1.5k ohm resistor, but there are 1/4 watt, 1/2 watt, and 1 watt resistor to choose from. I ask the guy that work there and he said it is important to know what watt do i need and said if i put iin a wrong watt resistor, i will blow something up, either the sensor, TCU or something else. Now can anyone tell me which one should i get, the 1/4 watt, 1/2 watt, or the 1watt resistor? Help, please.
Hey you know what the funny thing about your post is, i am not sure if you were asking me to try adjusting my TPS to fix the 1-2 gear shifting problem. Or you meant they are adjusting "MY" TPS in that pic. As a matter of fact, they were, that is a pic i took on my car when i was rebuilding my 88 Z31 Turbo, I post that pic a while ago to show a member (on this Forum, i think) where the TPS is located.Any, I went out again this morning to do the resistance test using a ohm meter, the resuld is telling me the Fluid temp sensor is in fact bad, so i am going to buy a 15k ohm resistor to trick the TCU. Still not sure which one to get, 1/4, 1/2, or 1 watt, can someone do the math for me, please. i am not good at that.driftkaztik wrote:hey, chek this out.. its adjusting your tps.
http://forums.f31club.com/phpB...t=413
You wont notice a difference..... but it is doing good!daltonnnn wrote:I installed one in my J30, but not because I had any problems. Yeah, I heard the q's trannys go out because it over heats. Honestly, I don't see a difference since the J motor and transmission isn't as big as the q.
you cant do that because otherwise it would starve the trans for fluid.shortlid wrote:Is there any way to put a kind of thermostat or thermal valve inline. So the ATF only flows through the cooler when hot??
