put front brake on rear brakes?
Fenvy
Car: 2005 350Z Base 6MT
anyone tried this?
I did my q45 brake upgrade on the front and now I am left with front pads, rotors, and caliper....
it might fit on the rear... anyone tried it? there might be some clearance issue with the control arm but just wondering if anyone tried it yet?
Nismo_Freak
Car: 89 Nissan 240SX
Got e-brake?
:D
book-ends
Car: ???? Nissan 240SX coupe S13
Who needs an e-brake? For all that emergency parking you do?
w1ngzer0
Car: Pfft. i don't own a box
jeansguy wrote:Who needs an e-brake? For all that emergency parking you do?
lmao. Well you don't want to lay on your transmission on a hill.
Fenvy
I must be really slow because I don't seem to understand... are you saying that the ebrake cable is directly connected to the rear caliper so that when the ebrake is engage the pads pull toward the rotor, bypassing the needed pressure from the brake line?
fuzion
Car: Cars.. Web/graphic design.. Yuppp
Thats why you have to turn the piston in the rear caliper.. to back it off.. the ebrake engages it
If you park your car on a hill without an ebrake and leave it in gear, its gonna roll.
Altiman94
Car: 1989 Nissan 240SX
actually, if you leave your car in gear w/o an ebrake, it wont roll. Go try it. You obviously have never don eit before.
stash420sx
my car rolled down a hill once. i thought someone stoll it at first cause it wasnt where i left it. hehe
cdlong
Car: '95 240sx
Loveless wrote:I must be really slow because I don't seem to understand... are you saying that the ebrake cable is directly connected to the rear caliper so that when the ebrake is engage the pads pull toward the rotor, bypassing the needed pressure from the brake line?
yes that's exactly right.
wangless
Car: '02 MBP WRX
whered you get your brakes from Loveless ?
Fenvy
from the junk yard silly ;)
fuzion
Altiman94 wrote:actually, if you leave your car in gear w/o an ebrake, it wont roll. Go try it. You obviously have never don eit before.
Actually, it will. I can put it in gear and push on it and the thing will roll (I usually nudge it back and forth to turn the fan clutch so I can unbolt it... all that stupid shroud stuff is a pain to take off and put back on)... it takes little effort on level ground to move it.. put your car in gear w/o the ebrake engaged on a hill and let me know what happens.
Hey loveless... just carry a big rock in the back of your car and stick it behind the back tire... or get one of those boots the bastard parking fairys use and lock her up ;)
Are the calipers from the rear of the Q better than the 240SX rear ones?
book-ends
IF your parking on a hill all you have to do is turn the front tires until they make contact with the curb......boom! How is your car going to move now? Magically roll over the curb while your gone? And if it did, the steering wheel will be locked so it would magically roll in a tight circle, blocking just a little bit of the street.....magically.
fuzion
What if there is no curb on the hill.
Florida240sx
Then park on a different hill. :D
fuzion
Damnit people! Im just trying to prove a point.. if the vehicle is on a hill in gear and the ebrake is not on it will roll... ;)
But yeah another hill would be good.. ;)
Fenvy
fuzion wrote:Actually, it will. I can put it in gear and push on it and the thing will roll (I usually nudge it back and forth to turn the fan clutch so I can unbolt it... all that stupid shroud stuff is a pain to take off and put back on)... it takes little effort on level ground to move it.. put your car in gear w/o the ebrake engaged on a hill and let me know what happens.
I don't know but I think the the q45 is also dual piston instead of one for the rear
Nathan
Note the name:Quote »stash420sx "] [/quote] Note the situation:Quote »my car rolled down a hill once. i thought someone stoll it at first cause it wasnt where i left it. hehe [/quote]
Does anyone else find this ironic?
fuzion
Marijuana affects the memory. :)
We know nothing of this!
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
Fuzion, what your saying make scents. If it were true that you didnt need a e-brake they why do ALL car have them? Plus have an e-break make thing more fun in emtpy parking lots.
Altiman94
well, my 240 is parked in my driveway, has about a 35* slope or so I'd say. No ebrake, car in first gear. It hasnt moved ever parked like that.
fuzion
Push on it :)
