Well, I disagree with the web postings that say the Max / I35 brakes are "too weak" for the car's weight. Feel free to link me to those conversations so we can educate some people.
If you can engage ABS in a panic stop, then you have sufficient brake clamping force. Period.
Your cousin's car may have had rotors replaced more often than you think is appropriate, but that doesn't mean they are the wrong size - that simply means either poor maintenance, the wrong pads, or lots of hard braking over thousands of miles.
However, you ARE on the right track in some areas, so let's look at a logical way to go about testing this:
Before you do ANYTHING brake-related, your first purchase should be tires. The A33 chassis will accept a significant tire upgrade easily. If you can find someone with a set of G35 Coupe wheels, a set of wider, sticky summer tires will amaze you.
Larger rotors and calipers increase unsprung weight. This
increases braking distance. So, while you may think you're improving your braking, you might just be breaking even. 18" wheels ALSO hurt your braking distances (again, more weight). You can believe the crap you read in Super Street, or you can believe people who actually have some track time under their belt.
After that, the upgrades should be simple: Aggressive pads, slotted rotors, and stainless lines.
Z31 87-89 rear brake hardware is NOT an upgrade for your car. It's a step backwards. If you had a '72 Z, then it's an upgrade. Bigger piston does NOT mean more braking force (your master cylinder, booster, and lines still contain the same column of fluid to move the piston). Larger rotors CAN give you more "leverage", but with the same clamping force, you're wasting money.
Also, your rear brakes only handle 20% of your stopping power. They're already well-suited for the job. You don't have to believe that, but it's a fact.
As far as front brakes, if you REALLY think you need larger rotors and calipers, I'd look into the 03-05 G35 Coupe Brembo setup and see if it can be retrofitted onto your car. I don't think it's a bolt-on swap, or there would be more of them running around.
If, after all of this unassailable evidence, you STILL feel the need to put bigger brakes o your family car, and you have money burning through your pocket, here ya go:
http://www.raceinspired.com/p-23218-ksp ... liper.aspx
