Put a VG30DE in a 86 300zx?
Discuss topics related to the VG and VE series engines.
abstractjunction
Car: 1986 Nissan 300zx N/A
1987 Nissan 300zx Turbo
Can one put a 93 300zx motor in an 86 300zx?
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
yes it can be done. im not sure what all is required but it can be done. i saw at 85 at a car show one time with a tt swap
abstractjunction
im lookin to keep mine naturally aspirated thanks for the input just wanted to see if there was a need to change motor mounts or move around nething in the engine compartment and come to think of it wat about the transmission? and drive shaft? hmm...o yea! and the ecu!?
s13drifter88
Im pretty sure u either have to swap the mounts or the cross member one but dont hold me to that, u may wanna actually compare the dimensions and measurements of the cross member to see if u need to swap that but im pretty sure its almost a straight forward swap but again... dont hold me to that. as far as electronics goes u may want to call and talk to wiring specialties and see what they can do and if they will do it. ill check around, keep doing so too and we'll figure this out
abstractjunction
nice thankx!
zmainiac
Car: 1988 300zx turbo
1988 300zx N/A
1984 300zx AE Turbo
1992 300zx N/A
2000 BMW 323ci
It would be much easier to just turbo the motor in there. you would have no room in the engine bay. you should look into putting a vg33e out of a pathy or exterra if you want N/A. same motor mounts, has been bored to a 3.8 with success, people have bored them to a 3.5 and then used vq45 pistons for a 10.5 comp beast. then you just need to get nistune for $500 and you can tune all you want.
abstractjunction
nice that sounds like exactly like wat ive been wanting to do thanks for the advice
Return to “VG30 / VE30 Forum”
