put a new thermostat and its leaking now! help
topairhead
Car: 180sx
ok i bearly put the thermostat and when i filled it up with coolant it just started driping !! wat can go wrong here i have a ka24deand the thing that was weird that the thermosat look way different then the one it had on it.i need help please anyone!
vancouverbc
Car: 1991 240sx
Have you tried tightening it? Chiltons calls for new gasket and sealer. Thermostat can be positioned wrong too but that would not cause leak.
vancouverbc
Car: 1991 240sx
Section LC of fsm describes procedure.
topairhead
Car: 180sx
yeah boght new gasket and silicone im good to go now
NCturbo75
Car: 2006 INFINITI M35...
Unless you are replacing a Original Nissan thermostat with another original unit, you will run into issues like that. There is no standard where companies have to make exact copies of the original. Just as long as it works and passes standard tests (if any), that's all that they are after.
topairhead
Car: 180sx
ok in instaled it againg im good to go now more more heating
