put 300zx brakes on my 240sx, can't get it to keep pressure.
Dirtfall
So I just rebuild the 300zx brakes i got. Put on the conversion lines and brembo blanks. Then i bled the master cylinder. Then bled the brakes pass rear, driver rear, pass front, driver front. Theres no air bubbles in the system. We bled them 2-3 times by now to make sure. When you pump on the brakes it will build good pressure. then you step leave the brake pedal alone for 30 seconds and next time i push in the brakes theres no pressure and you have to pump the brakes to get pressure again. Does anyone know is going on?
Dattebayo
You probably still have a little air in the system, you have to bleed and bleed and bleed it sometimes. You also may have a master cylinder going slowly bad.
Are you absolutely sure you did not cross thread anything? I would double check any connection you screwed in to make sure it is not leaking.
KDashy
Car: '97 Nissan 240SX
Are you using the 300zx brake master cylinder?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Are your bleeder screws on the top or the bottom of the caliper?
Dirtfall
KDashy wrote:Are you using the 300zx brake master cylinder?
No
positronone wrote:Are your bleeder screws on the top or the bottom of the caliper?
They are on the bottom.
I kinda think the master cyclinder might be going bad possibly. Does anyone know if a 300zx master cyclinder is a direct swap? Cause no one has any 240sx ones in town.
Dirtfall
Your a genius. I took the caliper off and flipped it upside down so the bleeder screw was up and sure enough a bunch of air farted out.
austins240
Car: 93 240SX HB, 89 Rolla GTS
actually you flipped it right side up. bleeder is always on top, as has been covered many times on the forums. did you search at all?
at least you fixed it. enjoy your brakes.
Clawhammer
You'll get a mushy pedal from the 240 MC. And yes it's a direct swap. Search around next time.
Dirtfall
I searched doing the caliper and rotor swap. I didn't even think about changing the MC till today so i didn't research it yet. Sorry it was such a hassle for you to answer my question. The brakes are a little disappointing with the 240sx MC so I think I'm going to upgrade to 300zx MC.
Modified by Dirtfall at 6:57 PM 9/16/2007
positron1
I'm assuming you have the fronts or do you have the full setup front and rear?
Dirtfall
I just got the fronts. I drove it a bit more today. They stop much nicer then i thought last night. I'm still used to my light little Honda hatchback. But i got tired of driving around a loud metal box. I love my kouki.
positron1
Sweet! I can't wait to get my fronts installed too!
94_240sx
Car: 94_240SX
positronone wrote:Sweet! I can't wait to get my fronts installed too!
I thought you already had z32 front brakes. I'm going to do mine all at once because I want to bleed only once and do the alignment after that.
