Nameless EJ6 wrote:Will you post a picture of that transmission with the slave cylinder? I want to look at it and see what is so different.
i dont have the slave cylinder, but basically the mount for the slave is past the fork closer to the driveshaft side. it actuates towards the flywheel, pushing the fork towards the flywheel on the outside. inside the bellhousing, the fork pulls the TO bearing away from the pressure plate.
it looks like the push type slave mount holes are still on my trans too, except they arent drilled. maybe if i got those drilled and got a new fork it would be a push type.
