First off, I know that there are a lot of threads on this topic, and I have a years of or residential electrician apprenticeship background. Yet, this still doesn't make sense to me. This diagram:
http://i41.photobucket.com/alb...1.jpg
confuses me. I've never worked with relays and I haven't had the time to figure out how they work so bear with me please. From what it looks like, I need to strip the black/white wire and connect it to the relay at two different contacts. A third contact goes to the push button. The fourth contact goes to black/yellow and black/green, which are spliced together. The second contact on the starter button simply goes to ground.
Is what I'm seeing the correct way to do it?
And, if someone could simply describe how a relay works and how I'd hook it up, that'd be appreciated.
Thanks NICO
