qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Fri Jun 27, 2008 6:49 pm
Seems as tho some of you are still under the impression a mod such as this alters the security of your car or the use of the ignition keys. It does not. You still use the key or keyless entry to get in, still put the key in the ignition, still turn it to the RUN position, instead of turning the key to the CRANK position you reach up and push the cool ENGINE START button.
The Q's security system won't care about this mod. Steering lock, trans lock, etc. would not be effected. Unless you butcher up some wiring doing the install, this mod would not effect anything other than your engine start up procedures.
Granted many don't have the experience that I have with this type of thing but I would estimate ~1 hour or less to install this mod. I agree that the only purpose would be the cool factor to do this but I'm now considering it, could be a good addition to my already "cool" Q, some people like to be unique, some like to keep it stock, to each their own.
How much did you pay for that S2K button? Just need the button, a SPDT relay ($1.50 and have dozens laying around the shop), few connectors or solder/heat shrink, and a bit of wire...no sweat.
