push button ignition
Post all your Nissan electronics, car audio and stereo questions here!
5hiftg3ar
im having problems with my push start button...im not sure what it is but sometimes when i try to turn on the car with the button the motor wont turn at all and i have to wiggle the wires or something to get it started. other times for some reason the button wont work if ive been driving the car for more than 20 minutes or so. any suggestions?
p.s. yes, ive thought of replacing the setup but im not exactly sure how to go about that so any1 that can help please let me know.
onosqv
Car: '92 240sx Vert
solder & heatshrink your connections. Sounds like you are crimping everythign together...
also, I'm guessing you are tapping into the wires directly - it's a lot of voltage to pass thru a lil push button, might want to considering doing a relay setup (which you can find on the12volt.com or google for setting up relays).
and yea, buy a better button start setup .
