DjPantsSpecR wrote:ddgsxr504, i have a similar problem, but on my auto car, so when it comes down to idle sometimes it sputters enough to die.
its not timing, ignition, aicv, knock sensor, cant find a vacuum leak, so this what im trying next. plug the tube with a nickel next to the exhaust manifold and see if anything changes. this way you dont waste any time removing a lot of stuff like the upper intake manifold, and it will help you diagnose the problem... if it is the problem, then do all the work
Actually I had this exact problem as well. It defenitely isn't the EGR, but it could infact be the BPT valve. Other than the BPT valve it can be the IACV (Idle Air Control Valve). It can get jammed up from years of use. If you usually feel hesitation or jerking, even having the idle die upto almost 2000RPM it can be the IACV, there are a couple of was to fix this situation.
First you can take your intake off and spray carb cleaner in to the intake system. If that doesn't work than it may need replacement.
It could also be the EGR/BPT but more than likely the BPT since it controls alot of the vacuum function of the EGR valve. I noticed this when replacing the EGR valve with a new one and replacing the BPT vacuum line.
Here is the link to zilvia where we discussed the issue of the IACV.
http://www.zilvia.net/f/showthread.php?t=95371
