Rolling Estonian »
https://forums.nicoclub.com/rolling-estonian-u93756.html
Tue Oct 21, 2008 1:32 am
Short answer - No you do not NEED endlinks
End links connect the sway bar (aka anti-sway bar) to the suspension.
and from how stuff works:Anti-sway BarsAnti-sway bars (also known as anti-roll bars) are used along with shock absorbers or struts to give a moving automobile additional stability. An anti-sway bar is a metal rod that spans the entire axle and effectively joins each side of the suspension together.
When the suspension at one wheel moves up and down, the anti-sway bar transfers movement to the other wheel. This creates a more level ride and reduces vehicle sway. In particular, it combats the roll of a car on its suspension as it corners. For this reason, almost all cars today are fitted with anti-sway bars as standard equipment, although if they're not, kits make it easy to install the bars at any time.
getting after market will only stiffen up the body roll. Is that something you need? want?
I say go for them.
