purple tints
Turb0wned
wassup with all these people with purple tints what do they see in it?? i seen about 5 or 6 cars today with purple tints
Rex
Car: None
Window tint?
If that's waht you're referring to, I've always seen that on cars that used "cheap" self tint kits. Or went with the $99 whole car deal and now after a year or so in the good "Deep South Sun" it's faded/turned purple.
I work in optics and we use a tint bathe for lenses the grey turns purple-ish as it ages or gets contaminated.
Turb0wned
yea window tints they looked purple to me
SeVa-S13
Car: '05 GTO 6spd
It's cheap and it fades to purple like that.Buy quality. ;)
Altiman94
Car: 1989 Nissan 240SX
they just turn purple after a while.
JustinM
Car: music (live)
Here's how to remove the faded purple nastiness: 1) grab a black garbage bag. 2)soak the window on the outside with soapy water. 3)lay the bag over the window (one layer) and let sit in the HOT sun, keep it wet. This will loosen the adhesive and you can peel off the tint from the inside and then use adhesive remover to clean up all the sticky stuff. This saves the defroster lines from being ruined by a razor blade. Let me know if this doesn't work or has been posted. Justin
midwestdrifter
i thought that the purple color was caused by the amonia in the glass cleaner.
justinM thanks for the tip. my girlfriend's car has that problem.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
my car had purple, peeling tints when i got it, but i took them off as soon as i got it.
the89_240
No actually I used to see a lot of this, working at an accessory store, I took tint off and redid it everyday. The ammonia in the cleaner is one of the things that makes it bubble up and foggy. No matter what kind of tint it is, it will fade to a purple, just depends how long. And to remove the tint, just get some stainless steel razor blades, peel back the tint and pull, then wet down the window and razor blade all of the adhesive off, this is the quickest and easiest way to do side windows, oh and stainless steel will not scratch glass, so as long as it is a new blade, don't have any worries about scratching the glass. But yes, you can't scrape over the defrost lines, it will mess em up, just pull it off like you did the sides, get a scrub pad, put some goof off on it, and go to town! :ylsuper
I H8 UR DSM
They are JDM.
maxpower
Car: WRX
I H8 UR DSM wrote:They are JDM.
midwestdrifter
wow jdm in that case im leaving mine on. heh. or better yet that sparkly rainbow tint. yeah
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
Nah son the best tint evar is that green window tint from pep boys y0!! OMG R0X0R!!111
Guffed
Car: cars and girls...What else is there??
I prefer just a nice smoke tint...even too black looks bad to me. But I hate having no tint at all. What's fun to do is when you race someone on the freeway, they cant see you right...so you just mess with them. first, they will drop it down next to you or wait for you to, but i just tap the brakes and then floor it in 5th to make it look like i dropped it down. They think their car is all fast for a bit, then you roll the window down (thank you power window one click thing) look over, smile, then drop it to 4th or 3rd and make a complete fool of them...well, it amuses me for some reason.
hannibal
Car: Red Line to Glenmont
ive got an ebay auction going for JDM purple tint, enough to tint your all your windows...reserve is $5000, current bid - $3000!!
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
but if you do peel it off of the back window make sure you don't cut the window defroster lines witha razor
