PURCHASING ECU for RED TOP QUESTION?? BUY STOCK VS SPL??
deathBooster
Car: 240sx under construction
guys just found out that the ecu for my redtop is messed up and need to buy a new one. now i found a stock redtop ecu for $180 and a SPL ECU modified by viel side with specification to recommend is change bigger fuel pump,straight?@mufflar,Air cleaner,Boost 0.8k (basic spec). ?? for $230????? which is a better buy?/? are the prices okay????? is the SPL worthed????
NEED SOME COMMENTS> THANK YOU
cheez80
Car: percussion =D
hi.
if you're going to buy a modified ecu, make sure you have the mods that it's tuned for, obviously.
i'd rather get a stock ecu and get an enthalpy tune.
