Purchased a spare ECU with copied J#$ chip
1qckser
Car: my wife, daughter, q45T,G20T,SE-R
http://cgi.ebay.com/ebaymotors...%3AIT
I have it from a good source that this person has done the same thing as AAAcomp, I will keep this one as a spare, that way if anyone needs it I will have it available.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Same as JWT with redline, speed limiter (lack thereof) and so on??
Hmmm, something tells me that there will be SOMETHING different about the JWT..
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
Does JWT just swap out the EEPROM?
elwesso
2007 BMW M Coupe
Yes....
Q45tech
JWT installs a eprom socket whereas the oem was soldered in.In Reality all one can change is WOT ignition advance [increase] and injector open time [reduction], tip in ignition retard amount and the rate it adds back in, speed limit, rev limit [hard and soft] .
1qckser
No difference Wes, this is the same ecu I currently have in my car from AAAComp and it works perfect, no speed limiter and rev limiter moved to 7300-7400 or whatever it is, Gleen is still offering the ecus by the way, I will have him do my TCU next
GreenQ45a
Q45tech wrote:JWT installs a eprom socket whereas the oem was soldered in..
So is the EEPROM* on that green daughter card?
Or is it surface mounted on the mainboard?
*EEPROM (electrically erasable programmable read-only memory)
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Theirs (according to them) is a proprietary daughter board (card) that replaces the OE & accepts the eproms. I've had several apart & it has their name on it.
