Purchased a 1995 Q and swapping interior into 1990.
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
I am swapping the interior from a 1995 Q into my 1990. I want to make it so that the headrests and lumbar support on the seats function in my car without having to swap out the entire electrical harness. I was going to swap the door control switches to my doors but I found that the connector for the window switch was a different style. I also noticed that the connector for the other controls on the switch assembly would plug into my door harness connector without any problems but the wiring colors are in different orders and the newer control only has 7 wires going to it with 1 black wire I guess for ground while the older control has 8 with 2 black wires. Please help Thanks.
Mattd1979
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
im not sure how that is going to work because the 94-96 Q had a different wiring scheme....
I think your in for a wiring nightmare. Personally I would just swap the 95 seat pads onto the earlier rails and be done........ Lot of work for stupid power headrests.. The lumbar you could probably make work pretty easy, should just be able to give it power.
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Sounds like a step backwards, since the 1990 has better seats.
