Purchase opinions, please ??
vtsnaab
Car: 2008 Nissan Rogue
Finding a replacement for my '08 Rogue has been quite educational.
The prices - sources & conditions are so wide ranging.
I've concentrated on finding cars from private sellers.
Thus far what looks to be the best car is a 2011 AWD with ~115k.
The seller claims to have bought it new in 2011.
What I can see of it *looks* very good & they want ~$4000 for it.
So...
It is in NY state ~4 hours drive from my part of VT,
Call me crazy & do criticize me if you think that'll help, but If I drive all the way there in a rental car, test drive it & look it over really well - it could still have defects which I will not see.
I'm considering buying it based upon speaking with the owner, seeing the pics & checking its VIN online - then just having it 'tran-sported' to me - but with so doggone many 'tran-sport' options that alone baffles me.
Lastly - my main gripe - it comes with only 1 key & those fancy things seem to cost hundreds to duplicate.
Any helpful thoughts/comments about any/all the above will be hugely appreciated.
Thanks.
PS: This forum had changed underlined words to say transmission & I was later able to fix it with some goodness from VStar650CL !!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That's a glitch in the website spell checker, I dunno why they don't fix it. Try a hyphen after tran, tran-sfer for example.
On older stuff like '11's you can generally get duplicate keys a lot cheaper from a smithy than you will from the dealer.
vtsnaab
Thanks for your helpful reply VStar650CL !!
For my '08 I was able to get a plain steel key made at HD - but in asking around all I've gotten for the electronic keys are quotes ~$300.
Hopefully there is a better way ?!?
VStar650CL
Technical Expert
There are scanners which can program Nissan smart keys, but as far as I know they'll all set you back at least the same $300. On the other hand, if you bought one then future lost keys will cost a lot less.
vtsnaab
Yes - looks like keys may be had cheaply enough, like this offer:
https://www.ebay.com/itm/387455987468
But getting them cut & programmed could be the killer, as you said.
Return to “Rogue Forum”
