Cicloturista »
https://forums.nicoclub.com/cicloturista-u278149.html
Tue Oct 17, 2017 4:33 pm
I have noticed it just the day after replacement of clutch, after a 150 km highway trip. It was the beginning of summer and since then this began to happen every time at the end of long journeys. Then, in winter it seemed disappear but it came back again in spring. The man who replaced the transmission thought a mouse or a small animal has entered and die in the air ducts and cleaned them and washed the engine but he did not find anything. I brought the car to another Nissan garage after driving for a while in order to make them smell and they told me that smell could be a transmission oil under the gear shift or anorther kind of oil, in case very difficult to clean. They also put the car on a ramp and looked under the car. They noticed in the mid section a small space on the exhaust system with traces of smoke where 2 pipes separate. They fixed them and gave me back the car. But problem still occurred. Again a third garage has not solved the problem and now, after 2 years, smell appears even after short journeys and also in winter. It is not typical oil burning smell but a kind of acrid, pungent smell, like plastic burning or garbage, or a mineral oil, for someone also like ash in ashtray. Hard to describe. It appears when I slow down and open the car windows, even not completely. It seems to be more pronounced on the driver side. It seems to come out from upper air ducts but not sure and I do not smell it through the air ducts when A/C is on. Terrible smell if I switch off the A/C. Once began, If I close the windows the smell becomes terrible and I have to switch on A/C to stop it. But it seems not coming from outside the car. No smell outside, or around wheels or engine. Anyone can help?
